Here’s How To Perform Cardless Withdrawal With Maybank MAE App
Unlike the SMS-based method, the new app-based option has no hard limit and additional charges.
[Image: Maybank / YouTube.]
21
Maybank has recently rolled out a new option for its customers that allows them to withdraw money from ATMs without their bank cards. Instead, the new option which is also called Contactless Withdrawal by the bank relies on its MAE app.
First reported by Rnggt, this is not the first time that Maybank has allowed cardless ATM withdrawal though. For years, customers have already been able to do so although the previous method utilises SMS to deliver the needed information which includes transaction ID and withdrawal code.
Before you can start withdrawing money using this method, you have to enable it for your MAE app first. So, the journey begins here:
Maybank MAE Cardless Withdrawal
Step 1: At the MAE home screen, look for the area that contains Quick Action widgets, and tap on Manage.
Step 2: In the “Customise Top Actions” section, choose the action that you feel that you don’t use often, and take it out by tapping on the “-“ icon. This will subsequently unlock other services listed in the “Available Services” area as you can only have four Top Action widgets at a time.
Step 3: Scroll down until you see the “ATM Cash-out” option and press the “+” icon.
Step 4: Once the ATM Cash-out option is already listed in the Customise Top Actions section, press the “^” icon to bring the action to the first, second, or third slot in the list. If you leave it on the fourth slot, then you will not be able to see it on the MAE’s home screen as the e-Duit Raya widget is currently occupying the first slot of the Quick Actions list despite whatever you saw in the previous Manage section.
Step 5: Tap on “Save Changes”.
Step 6: You should be able to see the “ATM Cash-out” widget on the MAE home screen. Tap it and enter your MAE/Maybank2U password.
mb mae cardless withdrawal howto 04
mb mae cardless withdrawal howto 06
Step 7: On the ATM Cash-out activation screen, tap on the T&C statement to agree to it, and tap Confirm.
Step 8: Check the masked mobile phone number on the One Time Password (OTP) screen to ensure that it is yours and then tap on the Confirm button to receive the OTP SMS.
mb mae cardless withdrawal howto 07b
Step 9: Enter the OTP code and tap on the checkmark button to confirm.
Step 10: The screen should now display the ATM Cash-out set up successful screen. You will also receive a phone notification and SMS as well.
mb mae cardless withdrawal howto 08
mb mae cardless withdrawal howto 05
As one can only start utilising the MAE-based cardless ATM withdrawal function a full 24 hours after activation, we have yet to experience the service ourselves as we had only activated the feature at 11:20 PM last night. Nevertheless, here are the steps to perform the withdrawal, based on the instructions listed by Maybank’s website:
Related Article Maybank To Enhance Its MAE App's Built-In Malware Shielding Feature
mb mae cardless withdrawal howto b01
[Image: Maybank.]
Step 1: Once you are at the ATM that supports the feature, open the MAE app, and tap on the QR code logo that is located in the centre of its bottom menu which would then activate its Scan & Pay QR code scanner.
Step 2: Scan the QR code that is shown on the ATM’s screen.
mb mae cardless withdrawal howto b02
[Image: Maybank.]
Step 3: Confirm your MAE credentials either through PIN code or biometric login.
Step 4: Enter the amount that you would like to withdraw and tap on the checkmark button. If the withdrawal amount is RM1,000 and above, you also have to enter the Secure2u code after this.
mb mae cardless withdrawal howto b03
[Image: Maybank.]
Step 5: Choose the account that you want to withdraw from and tap Withdraw Now.
Step 6: The processing screen would then appear and if your request is successful, the ATM would also begin to disperse your cash.
You can easily identify ATMs that support the new MAE-based cardless withdrawal feature by looking at their screen which displays the QR code that users have to scan in order to perform the transaction. This particular ATM which is located at the Maybank branch in Mid Valley Megamall Kuala Lumpur even has a small poster that highlights the new feature.
Unlike the previous SMS-based cardless cash withdrawal option which has a daily limit of RM300, there is no such hard limit for the MAE-based users as it depends directly on the customer’s existing daily withdrawal limit. This withdrawal option does not carry additional charges as well.
Meanwhile, Maybank has also said this feature will be made available at all of its ATMs in the near future. If you want to check it out now though, you have to visit one of the 998 ATMs that currently support the feature which the bank has listed on its website
Related Article Cute Tigers Have Been Spotted All Over The Globe; Here’s What They Mean!
Download
Filed Under mae cardless atm withdrawalmaybankmaybank cardless atm withdrawalMaybank MAE
Updated 2:16 pm, Tue, 17 May 22
SendShareShareShare8Tweet5
    Reviews
    HONOR Magic9 Pro Max Review: A Proper Refresh
    Tablets
    HONOR Pad X9b Max Announced In Malaysia With Large 13-Inch Display
