vivo Malaysia has announced that it will be launching its latest mid-range smartphone, the Y21T, in Malaysia tomorrow. The new handset will be available to purchase via the brand‘s concept stores, authorised dealers, official E-store, as well as its online stores on Shopee and Lazada.
The vivo Y21T sports a notched 6.51-inchh LCD display with 1600 x 720 resolution and 60Hz refresh rate, and features a plastic body that is available in Midnight Blue or Pearl White. Also onboard is a side-mounted fingerprint scanner, a SIM card tray that supports dual nano SIMs and one micro SD card, up to 4G connectivity, Bluetooth 5.0, Android 11 via vivo’s Funtouch OS 12 interface, and a USB-C port for data transfer and charging.
In terms of specs, the mid-ranger packs an octa-core Snapdragon 680 chipset with Adreno 610 GPU. This is paired together with 6GB of RAM and 128GB of internal storage, which is expandable up to 1TB via microSD. Powering the phone is a 5,000mAh battery with 18W fast charging capability.
Situated on the back of the Y21T is a triple camera setup which consists of a 50MP f/1.8 primary, a 2MP depth, and a 2MP macro sensor. Meanwhile, housed within the aforementioned notch is an 8MP “super night selfie” camera.
As mentioned earlier, the vivo Y21T will be available locally from 26 March onwards. Price-wise, the new mid-range smartphone will be retailing at RM 899.
(Source: vivo Malaysia press release)
