Dell has just unveiled two new 32-inch gaming monitors which are now available for purchase in select markets including Malaysia. Both monitors which are designated as the G3223D and G3223Q look identical to each other when it comes to physical design but not their display panel.
Even though both are equipped with Fast IPS panel alongside a refresh rate of 165Hz for PC or 120Hz when used with gaming consoles, the G3223D which is officially called the Dell 32 USB-C Gaming Monitor has a native resolution of 2560 x 1440 (QHD).
On the other hand, the G3223Q or the Dell 32 4K UHD Gaming Monitor has a much higher resolution panel as you can tell from its official name. They also conform to different levels of DisplayHDR standard at 400 and 600, respectively.
Dell also noted that the G3223D supports both AMD FreeSync Premium Pro and NVIDIA G-Sync technologies but the G3223Q officially only has support for AMD FreeSync Premium Pro. Furthermore, the G3223D is equipped with a USB-C upstream port that also has 15W power delivery alongside two HDMI 2.0 ports while the G3223Q comes with a USB-B upstream port and two HDMI 2.1 ports instead.
