Samsung revealed its Freestyle portable projector back in CES 2022. Now, the company has announced that it is available for pre-order in the local market, with availability beginning next month.
To go over its specs, the Samsung Freestyle portable projector has an auto-setup system that lets it calibrate itself, and can create images of between 30 and 100 inches. Image resolution may be capped at Full HD, but it also has a passive radiator for 260-degree audio projection. It is powered via USB-C, and takes media via wireless casting or Micro HDMI. Its cradle lets it rotate up to 180 degrees, and has an E26 lightbulb screw to allow it to hang like a lamp.
The Samsung Freestyle portable projector has a price tag of RM4999, and is available for pre-order until 31 March. Do so and you’ll also get a skin and a case, worth RM199 and RM299, respectively. The former lets you choose to replace the default white colour of the projector to green, while the latter makes taking it around a more convenient affair.
But most importantly, you’ll also get an RM998 e-voucher to redeem a battery pack for the Samsung Freestyle projector worth RM999. This can be redeemed between 1 April and 31 May. If you’re interested, you can place your pre-order by hitting the link below.
(Source: Samsung)
