While the Xbox Series X is not officially available here, it costs as much as a PS5. In other words, not exactly cheap. Though if you’re the target market for luxury fashion brand Gucci, then you’re probably wanting something more exclusive. So here’s the Gucci edition of the console.
The console has been dolled up with the brand’s signature pattern laser engraved all over. Which, to say the least, looks more subdued than the Spongebob or Ninja Turtles editions. You get two controllers to go with it, but the controllers get a simpler red and blue stripe on the left half.
In the year of the House’s centennial, Gucci and @Xbox come together to celebrate their respective anniversaries by creating 100 numbered Xbox Series X sets. The bundle appears in images by @HYPEBEAST @hypebeast featuring @EmeraldRose and @KojeyRadical. #GucciXbox pic.twitter.com/SkNdUfPSqV
— gucci (@gucci) November 12, 2021
The special Xbox Series X and its two controllers are packaged into a special Gucci carrying case which, on the outside, looks like it could be used for when traveling becomes a thing again. It’s got the usual extravagance that you’d expect from the brand, what with the brand’s pattern being all over, the red and blue stripe cutting straight down the centre, and the console’s signature green on the edges.
Naturally, something so exclusive must not only be prohibitively expensive, but also available in just as prohibitively small numbers. Only 100 of these Xbox Series X Gucci edition are made, and each costs US10000 (RM41535). They will be available on 17 November, and according to GamesRadar+, you’ll have to personally pick it up at one of the brand’s flagship stores.
(Source: Gucci [1], [2] via GamesRadar+)
