When the original LG PuriCare™ Wearable Air Purifier was launched to the world last year, it immediately caught the attention of consumers throughout the world. Fast forward to 2021, the improved second-generation model has since made its way to Malaysia.
With a battery life of up to 8 hours, the LG PuriCare™ Wearable Air Purifier is equipped with a dual-fan system which inclusive of H13 Grade HEPA filters and a respiratory sensor. The system dynamically adjusts its speed based on the user’s breathing rate and volume for a seamless experience.
The new model is not only much lighter than its predecessor but also has a new feature called VoiceON™ that allows the user’s voice to be heard much clearer when they speak with another person or on the phone. This particular feature can be easily activated through the power button located underneath the LG PuriCare™ Wearable Air Purifier.
At the same time, the company has also developed a perfect companion for the LG PuriCare™ Wearable Air Purifier. Also readily available in Malaysia, the LG PuriCare™ Wearable Air Purifier UVnano Case provides users with a nifty way to charge their LG PuriCare™ Wearable Air Purifier and keep it protected against bacteria.
This is thanks to the implantation of the UVnano technology, the case is able to eliminate 99.99% of bacteria from the LG PuriCare™ Wearable Air Purifier in just 30 minutes. You can take advantage of the cleaning technology with other items that you owned such as smartphones, glasses, home keys, and much more as long as they can fit into the LG PuriCare™ Wearable Air Purifier UVnano Case.
All the things we mentioned above are just a small part of what the LG PuriCare™ Wearable Air Purifier is all about. Do check out the full Lowyat TV episode above to learn more about this rather nifty piece of wearable tech and in case you still require further information about the new LG PuriCare™ Wearable Air Purifier after watching our video here, just head on to www.lg.com/my.
This video is brought to you by LG Malaysia.
