Made its way into Malaysia earlier this year, the ULED U900KF Android TV is Hisense’s first-ever foray into the 8K realm.
Powered by Hisense’s own Hi-View Engine, the massive 75-inch 8K Android TV has been equipped with a Quantum Dot Colour panel that can provide highly accurate colour reproduction. At the same time, ULED U900KF also has Full Array Local Dimming Pro which provides more than 100 local dimming zones that subsequently allows the 8K Android TV to deliver richer and more intense blacks.
The viewing experience of the new 8K Android TV is being enhanced further with the support of Dolby Vision HDR alongside Dolby Atmos surround sound technology. For gamers out there, you would be glad to know that the ULED U900KF is also able to deliver a refresh rate of up to 120Hz and supports Variable Refresh Rate (VRR) through HDMI 2.1 which means your game session would always be buttery smooth.
Being an Android TV device, this means the ULED U900KF also has access to the vast number of apps and services inside the Google Play marketplace as well as the ability to utilise Google Assistant. You can also easily control the 8K Android TV using your voice thanks to the built-in far-field voice control module that can capture voice from a distance of up to 5 meters.
As always, seeing is believing. So, make sure to check out the latest Lowyat TV’s episode above and learn how the new ULED U900KF 8K Android TV aim to please your senses.
Of course, you can always head on to www.hisense.com.my or your nearest Hisense dealers in case you need further information.
This video is brought to you by Hisense.
