Unless you’re already on one, getting a mobile data plan can be as tricky as mastering Crash Bandicoot: On The Run at your first attempt… but not impossible! This is especially true these days when the value of one is measured more by the amount of mobile data you get, rather than the number of call minutes or messages you can send. You have to balance the amount of data you need monthly versus the amount that you can afford to pay.
Hopefully a solution for your problem is the new Tune Talk Hi-Value Pack. More specifically, one limited-time offer that is available as part of this pack, which is “ngam ngam for you”. It is the Hi-35 plan, which offers – you guessed it – 35GB of mobile data for exactly RM35.
So what is it about this plan that makes it stand above the rest? To start, you get the option to add on boosters if you run out of high-speed mobile data. You can add on 1.5GB of RM3, or a whole 10GB for RM10. And depending on your streaming and gaming tendencies, this is definitely something to keep in mind.
Another benefit of the Tune Talk Hi-35 Ngam Ngam Plan is that your 35GB of mobile data has no hotspot restrictions. So you don’t have to worry about using up too much data via hotspot; you can share your 35GB of monthly mobile data with any number of your other devices. And you’ll definitely appreciate this if you have more than one device that connects to the internet.
Of course, Tune Talk isn’t skimping on the more commonly expected benefits with its Hi-35 plan. As is increasingly common, the plan also comes with unlimited calls to all other local networks. So it doesn’t need to be a choice between a plan that provides you with affordable data or one that gives you unlimited calls when you can get both in one plan.
And to top it all off, no pun intended, you get benefits that are unique to Tune Talk. One is the fact that you get points with every top up that you can use to redeem even more mobile data, flights with AirAsia, or even a smartphone. Another major plus point is the fact that you get RM50,000 personal accident insurance coverage for free if you top up RM50 or more a month, if your number has been active for at least two months.
You might be wondering, are there any restrictions to getting this deal? Not really. If you’re already a subscriber to another service, you can switch to Tune Talk and get access to this Hi-35 plan. If you’re already a subscriber to an existing Tune Talk plan, you can also upgrade to this one. Or, if you want to get a new SIM with a new number, that option is open too.
Of course, all these depend on getting it while it is still available, as the Hi-35 plan is only available for a limited time. You can find out more about it by visiting the plan’s page here. Alternatively, you can check out more of Tune Talk via its official Facebook and Twitter accounts.
This article is brought to you by Tune Talk.
