Home Gaming
Steam Deck Will Not Get Performance Boost When Docked
It will have the same performance level as when in handheld mode.
Steam Deck docked
(Image source: Valve.)
When Valve unveiled the Steam Deck, comparisons were immediately made to the Nintendo Switch. This is especially since its reveal followed the relatively unimpressive Nintendo Switch OLED. In the same vein, you’d probably think that it could perform differently in its handheld and docked states. That doesn’t seem to be the case, as the Valve handheld performs similarly in either mode.
PC Gamer reports that Valve has designed the Steam Deck to not come with a higher power mode when docked. Rather than having to deal with two different modes, the company decided that it will focus on the Deck’s primary use case scenario, which is handheld.
Steam Deck handheld
Though if you choose to, you can still plug a Full HD TV to the dock, and play the Steam Deck that way if you don’t like the 800p resolution. That being said, chances are you’ll see a slight performance drop when you do so.
Valve has previously promised a minimum framerate of 30fps while in its 800p handheld mode. Ideally, you’d want to expect this to go up to 60fps, but that could be made more challenging if the Steam Deck was made to deal with more pixels than it was primarily made to deal with.
(Source: PC Gamer)
RELATED:  Helldivers 2 Beta Liberates PC Installation Size By 85%
Filed Under 800pdockgamingHandheldPCperformancesteam deck
Updated 4:35 pm, Mon, 9 August 21
http://lowy.at/k89jS
SendShareShareShare1Tweet1
    Transportation
    Cyber Security
    Samsung Galaxy S26 Ultra Users Report Eye Strain, Headaches Over Display Issue
