Many of us think that dirty air is something that can only take place outside of our homes. Well, that’s not the case actually, dirty and polluted air is inside your home too.
Now that the majority of us have to stay home as much as possible and not be able to go out as often as we like, the risk of having stale and dirty air inside the home is much higher. Hence, introducing an air purifier inside your home could be something that you may want to consider.
Not all air purifiers are made the same though. If you prefer to have something that is powerful enough to deliver fresh air to every part of your home, look no further than the LG PuriCare™ 360º Air Purifier.
Thanks to its unique 360º design that works hand in hand with the Clean Booster feature, the LG PuriCare™ 360º Air Purifier is capable of cleaning the air from even the far end of the room. Not only that, the LG PuriCare™ 360° Air Purifier has been proven to remove 99.999% of airborne dust and allergens as small as 0.01㎛.
It is also equipped with a built-in PM1.0 and gas sensor system which provides real-time air quality measurement to users. It’s also worth mentioning that LG PuriCare™ 360° Air Purifier is endorsed by The British Allergy Foundation, Asthma & Allergy Foundation of America, and Korea Air Cleaning Association.
Since the LG PuriCare™ 360º Air Purifier is also part of the LG ThinQ smart home ecosystem, this means you can easily control its features and check the air quality level of your home even when you are away. Seeing is believing, so make sure you check out Lowyat TV’s episode above and visit lg.com/my/puricare to learn how the LG PuriCare™ 360º Air Purifier can become the perfect companion for your home.
This video is brought to you by LG PuriCare™.
