Logitech G Launches G335 Wired Gaming Headset; Retails At RM269
Sadly, the Mint Green colour scheme isn't available on our shores.
by John Law
July 1, 2021
Logitech G G335 800
Logitech G recently launched the G335, its latest wired gaming headset. The headset draws much of its design inspiration from the brand’s G733 Lightspeed wireless gaming headset.
Because of its familiar design, the G335 also features a lightweight chassis, allowing the headset to weigh in at just 240 grams. In other words, it is just a little heavier than the pre-cooked weight of a regular steak. On top of that, the fitted earcups are slimmer than the ones used on the G733, while the attached 3.5mm audio jack allows for easy plug-and-play.
Specs-wise, each earcup houses a 40mm driver that has a frequency response between 20Hz and 20KHz. In addition, they have an impedance of 36Ω. with a sensitivity of 87.5 dB. As for the attached microphone, it has a frequency response between 100Hz and 10KHz and is Discord certified.
Logitech G G335 2
The Logitech G G335 is already available for purchase. It retails at an SRP of RM269. At the time of writing, the Mint colour variant of the headphone is not yet available in Malaysia.
Related Article Logitech G Pro X3 Superstrike Leaked By Amazon
Filed Under g335Logitechwired gaming headset
Updated 9:43 am, Fri, 2 July 21
    Data Breaches
    Cyber Security
