Just two months after launching Ionic Touch, Illegear has once again added another thin and light laptop into its catalogue. Called Arté, the new model is equipped with a magnesium alloy body and weights at just 1.04kg.
Aside from that, the new Illegear Arté also carries a 14-inch IPS display that has native resolution WQXGA (2560 x 1600) as well as a 90Hz refresh rate and maximum brightness level of 400nits. In terms of firepower, customers can choose either Intel Core i5-11300H or Core i7-11370H which came from the 11th Gen Intel Core H35 family of processors.
When it comes to graphics, the Arté relies on the Intel Iris Xe GPU that has been integrated into both processors. Regardless of your processor option, the base model comes standard with 16GB of RAM and 500GB solid state drive while the laptop itself is able to support up to 64GB of RAM and two 2TB solid state drive.
Price-wise, the new Illegear Arté with Core i5 starts at RM 4,599 while the Core i7 variant can be obtained from RM 4,998 onwards. As part of its launch promotion, each Arté will be upgraded to 512GB Samsung PM981a SSD while Illegear will also apply Thermal Grizzly Kryonaut and perform colour calibration on the customer’s unit without any extra cost.
