Gaming peripheral maker Razer announced its first gaming chair called the Iskur last year. Now, the company has a slightly more affordable version of it called the Iskur X. And when we say slightly, we really mean only slightly.
But first, let’s look at the Razer Iskur X itself. It mostly shares the look of the full Iskur. It supports the same maximum weight too, at 136kg. While there’s no mention of maximum height supported, it’s probably reasonable to assume that it’s the same too.
So what’s missing to make the Razer Iskur X come with a lower price tag? There are two notable omissions, though the more important one is probably the built-in lumbar support. It still has the same snake belly pattern, but with the lumbar support gone all that’s left is a regular backrest. The armrests have also gone from 4D to 2D.
But since, the built-in lumbar support is gone, Razer has also announced its own lumbar cushion, and a head cushion to go with it. Both are meant to be usable with any other gaming chair out there. The head cushion could see use with the regular Iskur too.
Now for its price. The Razer Iskur X is priced at RM1499. The lumbar and head cushions are RM199 and RM259 respectively. Put them all together though, and it’s a total of RM1957. The cushions will be available starting 3 June via the Razer online store for Malaysia. As for the Iskur X itself, the company says it will be available starting 10 June at major gaming peripherals and IT stores, as well as via the official Razer Store on Lazada and Shopee.
