Hisense Malaysia today has launched two additions to its smart TV lineup with the new A6500G (shown above) and A6100G models. The former operates on Android while the other comes with the brand’s own VIDAA operating system. Both TVs are available in various screen size options, all of which offer 4K resolution and a variety of smart features.
The A6500G comes in 50, 55, 65 and 70 inch sizes in terms of display, while the A6100G is offered in 43, 50, 55, 58 and 65 inches. As for visual enhancements, the duo features a built-in UHD AI upscaler that resizes and enhances lower resolution images to 4K, as well as a noise reduction function across all models. Available exclusively on the 70 and 65 inch variants of the A6500G is the Motion Picture Enhancer feature which can reduce image judder, and also HDR support that brings out crisp and detailed visuals.
Audio-wise, the A6500G series features Dolby Atmos tuned speakers that output sound from the top of the TVs, which is intended to be bounced off from the ceiling to simulate an immersive surround sound experience. Meanwhile, the A6100G comes with speakers with DTS Studio Sound support which provides clear voice audio by amplifying dialogues apart from background noise.
Both models also come with multiple HDMI ports, USB slots, as well as Wi-Fi and Bluetooth connectivity. In terms of software, the Android-based A6500G enables users to download various apps from Google Play, utilise Google Voice Search, and much more. The VIDAA-based A6100G, on the other hand, features a straightforward and easy to navigate interface to cycle through various pre-installed applications such as YouTube, Netflix and so on. This series also allows users to use their smartphones as a remote controller for managing various TV functions via the Hisense RemoteNOW app.
The A6500G Android and A6100G VIDAA TVs are available for purchase starting from today via local authorised Hisense dealers nationwide, which you can refer to by visiting this link. As for pricing, the 50-inch variant of the A6500G retails at RM2,899, the 55-inch at RM3,299, 65-inch at RM4,399 and the 70-inch at 5,799. Meanwhile, the A6100G starts from RM1,999 for the 43-inch, RM2,699 for the 50-inch, RM2,999 for the 55-inch, RM3,299 for the 58-inch, and finally RM3,999 for the 65-inch variant.
(Source: Hisense Malaysia [1] [2] | Header image: Hisense A6500G Android Smart TV)
