The Lenovo Legion Duel 2 gaming phone is still quite fresh off the oven. And already, it’s been put through some abusive stress tests of the physical kind. And as is the case with many bend tests by JerryRigEverything, the phone ends up snapping in two. Well, three, quite immediately after.
As usual, the durability test starts off okay. The Corning Gorilla Glass over display scratches as Mohs hardness level six. That’s to be expected. The glass pieces at the back also hold up quite well. Then, at the end of the video, comes the notorious bend test.
And as the title of this article suggests, this is when the Lenovo Legion Duel 2 snaps. Much like with the ASUS ROG Phone 5, the weakpoint here is the antenna line. But since there are two of these lines on either side of the central camera bump, the phone breaks just as easily on both sides.
Again, just like with the ROG Phone 5, the Lenovo Legion Duel 2 isn’t expected to be intentionally bent that way. But it still does mean that you’d want to be careful with it. For what it’s worth, the initial unboxing by JerryRigEverything shows that the phone comes with a plastic case in the box. But that’s unlikely to be enough to give you peace of mind.
(Source: JerryRigEverything / YouTube)
