The Internet has become an integral part of our life as it has certainly helped empower our work as well as the way we learn and play. This holds true regardless of whether we are at home relaxing with our loved ones, out on the streets running errands or even getting some sweat out by cycling miles and miles on the open roads.
Doesn’t matter if you are at home or on-the-go, Celcom has your needs covered via the super-fast Celcom Home Fibre ™ and the wide-reaching Celcom MEGA ™ postpaid services. Now, what if we tell you that these two plans can come together under one single bill?
Well, say hello to the new Celcom MAX ™ then whereby you can now conveniently have both Celcom Home Fibre ™ and Celcom MEGA ™ postpaid plan in one single bill. However, convenience is just at the tip of the iceberg though.
So, let’s jump in and see how Celcom MAX ™ can enhance how you learn, work, & play.
As Work-From-Home (WFH) has become a new norm for the past year, you clearly need not just high-speed Internet alone but QUALITY high-speed Internet. Available with speed of up to 1Gbps*, Celcom Home Fibre ™ didn’t just deliver blazingly fast Internet directly into your home but also make sure that you can get the best out of it for your work and beyond.
This is because subscribers are being provided with the high-performance AX10 router that is designed to deliver a strong and stable Wi-Fi connection. With Celcom MAX ™, things get even better as it adds the Celcom Mesh Wi-Fi devices into the picture.
For those who aren’t familiar with them, these devices are designed to ensure that you are able to obtain high-speed Internet connectivity in all corners of your home. Celcom MAX ™ provides you with these Mesh Wi-Fi devices for free if you sign up with Celcom Home Fibre ™ 500Mbps / 1Gbps* plans or just RM 25 per month if you prefer the Celcom Home Fibre ™ 100Mbps and 300Mbps instead.
Need a timeout from work or looking for something to watch when you wind down at the end of the day? Well, Celcom MAX ™ got you covered as well with MAX Entertainment!
If you choose the Celcom Home Fibre ™ 300Mbps, 500Mbps, or 1Gbps* plan through Celcom MAX ™, you will then receive a free 6-month subscription to some of the most well-known video streaming services in the market including iflix or iQIYI.
Now, don’t you think it would be great to enjoy those streaming services on a large TV set? Fret not, Celcom MAX ™ can make that happen too!
By signing up for Celcom MAX ™, you can enjoy MAX savings and get your hands on a 60-inch Sharp Aquos 4K UHD Android TV for RM 2,400 instead of its original RM 4,999 price tag. Not only that, you would receive another RM 500 voucher that you can spend at the eSharp online store!
Don’t worry if you feel that the 60-inch TV is too big for you as there’s also the 42-inch Sharp Aquos Full HD Android TV which can be purchased for RM 1,200 as opposed to its standard price of RM 1,749. Similarly, it will also be accompanied by an eSharp online store voucher that is worth RM 100.
The advantage of Celcom MAX ™ doesn’t end just there. If you are in the market for a highly mobile and versatile device, you have come to the right place as Celcom MAX ™ is now offering Microsoft Surface Go 2 128GB or Microsoft Surface Pro X 256GB with savings of up to RM 638.
See? Once again, Celcom MAX ™ brings convenience directly to you but wait, we are not done yet. We are saving the biggest advantage for the last: another reason why you should consider Celcom MAX ™ is the fact that it also comes with a lifetime savings of RM 21 each month!
That’s right; as long as your Celcom Home Fibre ™ and Celcom MEGA ™ postpaid accounts remain active, the discount is yours to enjoy for years to come. That is equivalent to RM 252 of savings per year!
A word of caution though: Celcom MAX ™ is only available for a limited time! So, make sure to grab all the advantages provided by Celcom MAX ™ as soon as you can by heading on to the nearest Celcom bluecube or Celcom Certified Partners nationwide.
If you need further information, you can check out celcom.com.my or reach out directly to the telco via its official Facebook and Twitter.
* Celcom Home Fibre ™ 1Gbps only available in Sabah at the moment.
This article is brought to you by Celcom.
