Despite its expected Q4 launch window later this year, it is never too early for iPhone leaks. New information regarding Apple’s upcoming 2021 flagship model – which would unlikely be named as the “iPhone 13” because of obvious reasons – has surfaced online, thanks to leakster Max Weinbach via YouTuber EverythingApplePro.
This time around, it is said that the new handset would feature a battery-efficient LTPO (low-temperature polycrystalline oxide) display, with a high refresh rate of 120Hz – the highest ever featured on the company’s smartphone releases. An even more interesting tidbit from Weinbach revealed that this model may also be Apple’s first iPhone to come with an always-on display. This suggests that the upcoming model would be even more power conserving than its predecessors – something that cannot be proven accurate until we are able to test it out for ourselves, which is still a long way to go.
The always-on display feature has been a standard on most Android smartphones, and was already introduced on the company’s Apple Watch wearables starting with the Series 5. The leak detailed that notification bars and icons will be displayed for a limited amount of time on-screen when the phone is locked, while the battery and clock indicators would be visible throughout.
Exclusive iPhone 13 Leaks (feat. @MaxWinebach). Special thank you to @CConceptCreator for the modeling help with the intricate details 👌 https://t.co/kZMcOq3K4M pic.twitter.com/KN25cbvktB
— EverythingApplePro (@EveryApplePro) February 14, 2021
Weinbach added the 2021 iPhone would also feature upgraded cameras, but was not specific regarding their improvements. Instead, the leakster said that the handset would come with a better ultra-wide camera, automatic astrophotography, and a Galaxy S21-like portrait video mode. Other than that, he claims that the handset’s rear case would sport a grippier matte finish and the built-in MagSafe magnets are stronger too.
Keep in mind that the MagSafe feature on the current iPhone 12 models is known to cause interference with medical implants, as previously reported. Therefore, Apple’s precaution of keeping its iPhones away from these devices would still apply to the supposed upcoming models, given its increased magnet strength.
As a quick recap, earlier rumours of the 2021 iPhone specifications suggests a smaller notch on its display, and an in-display Touch ID feature – another purported first for Apple’s smartphones. Weinbach’s recent leak also corroborated on an earlier report claiming that the upcoming models would sport a similar design to last year’s iPhone 12 series, but with some minor tweaks.
As usual, we highly advise to take the provided information with a pinch of salt despite Weinbach and EverythingApplePro’s track record in regards to smartphone leaks. With the 2021 iPhone’s expected announcement still being far off, we can expect even more rumours and leaks to surface along the way.
(Source: Max Weinbach via EverythingApplePro | Header image: iPhone 12 Pro)
