Ceiling fans aren’t usually something that you’d think needs WiFi. But Panasonic Malaysia has a number of models of just that. Aptly called the WIFANs, you can control them via mobile app in addition to the remote control they come with.
These WIFANs come in four distinct models. The most basic among them has three fan blades and measures 48 inches. On the other hand, the advance model comes with five blades and measures 60 inches. Both have a variant with LED lighting, which provides four different lighting modes.
To get these WIFANs to work, you’ll have to connect them to your WIFI router at home. These will then allow you to control them using the mobile app. Your mobile device doesn’t have to be connected to the same network for this to work either. This allows you to remotely turn them on or off, adjust fan speeds, or even turn on their LED lights on applicable models.
If you’re interested, the most basic model, which is the three-fan WIFAN, is priced at RM849. If you want one with the LED lighting, it will cost RM949 instead. As for the five-blade fans, these are priced at RM999 and RM1049, respectively.
(Source: Panasonic Malaysia)
