Besides Razer’s usual fare of Blade gaming laptops and its external graphics enclosure (eGPU), the gaming accessories and peripherals brand also launched its Tomahawk desktop PC casings for the Malaysian market. Specifically, the lineup comprises variants for both an ATX build or a mini ITX PC.
Both Tomahawk casing feature suicide tempered glass side panels, support for radiator sizes up to 360mm, removable storage trays and PSU drawers, plus the standard fare of USB 3.2 front headers and audio ports. Oh, and there’s also a USB-C port at the front as well.
For the Mid-Tower chassis, do note that the casing supports motherboards from the ATX, mATX, an mini-ITX range, while the Mini-ITX chassis only supports motherboards of its namesake, plus mini-DTX form factors. Due to the latter’s considerably smaller size, it will only support SFX and SFX-L PSUs. Lastly, both chassis are equipped with Razer’s Chroma RGB.
Pricing for the Razer Tomahawk Mini-ITX and ATX are set at RM1199 and RM1099, respectively. As for availability, the Mini-ITX chassis will be available starting this month, while the ATX variant will only be available at all authorised dealers and partner stores from the end of November onward.
