It was just last month that the realme 7 and 7 Pro were announced. And now, the company has announced the realme 7i, and alongside it, the realme C17.
Starting with the realme 7i, this has a lot in common with the base realme 7. To start, it has a similarly-sized 6.5-inch HD+ display, as well as the 90Hz refresh rate. Beneath the screen, the phone runs a Qualcomm Snapdragon 662 chipset, 8GB of RAM, 128GB of internal storage, and a 5000mAh battery that supports 18W fast charging.
The cameras on the realme 7i are also virtually identical, sporting a 64MP main camera, an 8MP wide angle camera, as well as a macro and monochrome depth sensor of unspecified pixel count. In front, it has a familiar 16MP shooter.
As for the realme C17, this, in turn, is very similar to the realme 7i, with some performance dips. It also has a 6.5-inch HD+ display with a 90Hz refresh rate. Inside, it has a Qualcomm Snapdragon 460 chipset, 6GB of RAM and 256GB of internal storage. The battery and its support for fast charging is also identical, at 5000mAh and 18W, respectively.
For the rear cameras, the realme C17 has the same configuration as the realme 7i, except for the fact that the main camera is a 13MP camera instead. And in front, it comes with an 8MP camera.
The realme 7i is available starting today, 13 October, from 2PM onwards on Lazada for RM999. Get it today and the company will also give you a 10000mAh powerbank for free. If you prefer to get it from physical shelves, then this will be available from 17 October onwards.
As for the realme C17, it will be priced at RM899. The company did not say when exactly it will be available, but announced instead that Digi is a telco partner.
(Source: realme Malaysia / Facebook)
