EVGA’s Kingpin GPU lineup is often regarded as being some of the most highly tuned and overclocked set of cards on the current market, complete with some over-the-top cooling solution. To that end, it shouldn’t surprise anyone that the brand has released an NVIDIA GeForce RTX 3090 with a custom AiO cooler and boy, is it massive.
Dubbed the GeForce RTX 3090 Kingpin, EVGA’s custom cooler was designed in collaboration with none other than Vince Lucido, the man and legend behind Kingpin Cooling. The card itself only features a 90mm attached to the end of the PCB, but the GPU itself is affixed with a massive 360mm radiator at the end of it.
In addition to that monstrous radiator, the card also features a flip-up rear-mounted display that undoubtedly shows the details of the card’s temperatures, especially if you’re planning on overclocking the card. Speaking of overclocking, it should also be pointed out that Lucido managed to achieve 2.58GHz on the RTX 3090 Kingpin, albeit with liquid nitrogen (LN2) and not with the cooler you see at the top.
At the time of writing, EVGA did not say when or if its GeForce RTX 3090 Kingpin will reach our shores, neither did it provide pricing for it.
(Source: Vince Lucido via Facebook, Hot Hardware)
