Another day, another round of price drops for Zotac Malaysia and Sun Cycle, the official distributor for the brand in Malaysia. Having already slashed the pricing for its custom-cooled GeForce RTX 2070 Super, RTX 2080 Super, and RTX 2080 Ti, the brand has now turned its gaze towards its entry-level RTX 2060 Super cards.
Dubbing it as the second wave of its “Massive Knockdown” initiative, consumers can now purchase an RTX 2060 Super Twin fan for RM1599 and RTX 2060 Super Amp Extreme for RM1759. Specs-wise, both cards are equipped with 8GB GDDR6 graphics memory with a memory bus of 256-bit. Additionally, but the two cards are cooled by Zotac’s IceStorm 2.0 cooling solution. Also, if you want RGB lighting in your card, then the Amp Extreme model is the one you want here.
As usual, this new price cut is only applicable to Zotac cards and should soon be reflected in the price list of all authorised and participating PC shops that stock the card. So, if you’re not seeing the new pricing for the cards yet, do be patient as these stores will undoubtedly update them over time.
(Source: Zotac Malaysia)
