The recently launched OPPO Reno4 series have been revealed to be smartphones with excellent performance and features, especially with the Reno4 Pro. It boasts a fantastic 90Hz 3D display, powered by a Qualcomm Snapdragon 720G chipset with 8GB RAM and 256GB of internal storage, and supports 65W SuperVOOC 2.0 fast-charging. With this, you can be certain that this latest offering from OPPO is well equipped to handle various daily tasks and even gaming.
But its excellence is not limited to just that. The Reno4 Pro also comes with a slew of commendable camera hardware and modes to not only enable you to produce high quality photos and videos, but to also help unleash your own creativity and talent. Regardless if you’re capturing photos or recording videos for your own personal projects or for social media, the OPPO Reno4 Pro is designed to bring out ‘Clearly The Best You’.
Colours to behold
Bring out the artist in you with several of the Reno4 Pro’s brilliant photo modes such as AI Color Portrait mode to create photos with a dramatic effect that highlights and isolate certain colours, while leaving the surrounding to appear in monochrome. Utilise the phone’s Night Flare Portrait, which enables you to capture images with blurred “bokeh” backgrounds in low-light – as if you were using a DSLR camera!
Thanks to its impressive 48MP High-Definition Main Camera, you’ll be able to snap gorgeously sharp and vivid images that showcase a wide range of colour and detail. Of course, you need not worry about poorly lit locations either – thanks to the Reno4 Pro’s impressive low-light technology which retains an image’s colours and details regardless of how dark your subject or environment are. With the 48MP camera, you’re also able to capture photos in even higher resolution with the Ultra Clear 108MP mode which brings out an incredible level of detail and textures in a single image.
To get an even closer look at faraway objects, you can easily rely on the phone’s telephoto mode which is able to zoom up to 5x. You’ll be surprised at what tiny details you may have missed at first glance you get a close up look at certain distant subjects. As for capturing more in a single frame, the Reno4 Pro is equipped with a 8MP ultra-wide angle camera to ensure that you won’t leave out anything within your view.
The Reno4 Pro’s front-facing 32MP camera isn’t left out from these glorious features either. On top of its already remarkable image quality, you can also apply modes such as Portrait and AI Portrait Color to your selfies as well for a more stylised shot!
Professional-grade videos
The OPPO Reno4 Pro isn’t pulling any stops in terms of videography either. You can expect to capture excellent 4K videos at 30p, and even enjoy it later on a high definition TV with no loss in quality. Alternatively, you could also record in Full HD at up to 60p and the fun doesn’t stop there either.
Remember the awesome AI Portrait Color mode mentioned earlier? You’ll also be able to use that mode with the Reno4 Pro’s video capture as well. Give your videos a more stylised look by isolating colours from a black & white backdrop – completely in real-time! In addition to this, you could record in cinematic monochrome as well. Again, this is done in real-time, which does not require you to edit separately from the phone’s camera app.
Slow-motion videos are mesmerizing to watch, and while this video feature is nothing new in current generation smartphones – the OPPO Reno4 Pro is taking it several notches higher. As part of its rich selection of modes, the phone also includes the ability to record with AI Slow Motion at a staggering frame rate of up to 960fps. See fascinating sights or fast action movements like never before in glorious slow motion with the Reno4 Pro!
Lastly, video recording with the Reno4 Pro will also allow you to experience its highly impressive Ultra Steady Video 3.0 feature. This would enable for a stabilised video-capturing experience, which is as if you’re actually using a gimbal or shooting via an action camera. Even better, you could also use this feature when using the phone’s ultra-wide angle lens to capture even more objects and scenery in frame!
Ready to go
It’s without a doubt that all these impressive features on the OPPO Reno4 Pro will require a significant battery capacity. To ensure that you’ll have more than enough to fully utilise the phone for your daily drive and then some is a massive 4,000mAh battery, which could last you for more than a day without charge!
Even if you’ve managed to spend a large amount of its energy, you can easily top it up in no time with the Reno4 Pro’s 65W SuperVOOC 2.0 fast charging technology. How fast exactly? A full 100-percent charge will require no more than 36 minutes, which is very convenient if you’re in a hurry! OPPO’s 65 SuperVOOC 2.0 is also safe to use, and comes with the Safe Fast-Charge System Certification by TÜV Rheinland.
A slim and gorgeous display to match
Of course, taking beautiful photos and videos will require a screen that is capable of showing them off, which is not a problem at all for the OPPO Reno4 Pro! This is thanks to its brilliant 6.5-inch 3D Borderless Sense Super AMOLED display. Browsing your gallery and using the phone for your daily drive is made even better thanks to its fast 90Hz refresh rate that provides you with a visually swift experience. Furthermore, the Reno4 Pro’s display also features a 180Hz touch sampling rate which greatly benefits you in terms of user interaction and especially for gaming!
The phone’s incredible display, impressive hardware, and high-end camera setup are all packed in an unbelievably thin and compact body. The OPPO Reno4 Pro measures at 7.7mm thick and weighs only at 161g!
Clearly the best you!
The new OPPO Reno4 series of smartphones have been designed to bring out the best of you. Whether it’s to showcase your creativity in photography and video creation, or to be used to fulfill your daily use and gaming – the OPPO Reno4 Pro and Reno4 are clearly your best choice.
The Reno4 Pro is available at RM2,399, while the standard variant is priced at RM1,699. You can pick up your very own Reno4 series smartphone at the OPPO Concept Store, official online store, authorised dealers, as well as its E-commerce partners such as Lazada [1] [2] and Shopee [1] [2], telco partners and chain store partners.
OPPO is also currently holding a Reno4 series roadshow at IOI City Mall, Putrajaya from 6 to 17 August 2020. Be sure to give it a visit, especially if you wish to try out and experience the new smartphones yourself!
Additionally, the brand will have exciting giveaways during the roadshow for any purchase of the Reno4 series as well! Those purchasing the Reno4 are entitled to receive a free Reno Backpack, while Reno4 Pro buyers will reveive a free VOOC flash charge powerbank!
That’s not all! Exclusively for the OPPO Reno4 Pro, users with My OPPO App will get RM100 KLOOK discount vouchers for the first 2,000 redemption on Reno4 Pro. Upon redemption, three lucky members will stand a chance to win the grand prize of a 3D2N Island Escape at the Taaras Beach & Spa Resort with ATR Flight Experience! The first 2,000 OPPO Reno4 Pro users will also be given a complimentary 120GB of OPPO Cloud Storage for 6 months which can be redeemed on My OPPO App!
This article is brought to you by OPPO Malaysia.
