Hours after the official unveiling of Samsung’s Galaxy Note20 series, Razer seems to already have some custom casings for the two phones at the ready. Officially, it’s called the Arctech Pro and as with all Razer products, the casing is not your standard protective accessory.
At a glance, the Arctech Pro doesn’t seem to be slim and looks moderately chunky, and for a good reason. As per its official product page, the casing is drop certified, meaning that it should protect the Note20 or Note20 Ultra from individuals with butterfingers.
Moving on, the Arctech Pro is also layered with Thermaphene cooling technology, which is just a fancy way to describe the special heat-dissipating layer found on the inside of the casing. Designed to keep the Note20 and Note20 Ultra cool and comfortable to the touch while you game on the phone. Additionally, the casing is also coated with an anti-bacterial coating that prevents bacterial build-up from prolonged use.
At the time of writing, the official Razer page lists down the casing with an SRP of US$44.99 (~RM188). On that note, there is no news about local availability or pricing, at current.
(Source: Razer)
