Logitech has finally made a new racing wheel, and its called the G923. And while it may be difficult to tell the difference between it and prior models at a glance, it does come with quite the killer feature. It’s called TrueForce, and it sounds like quite the impressive force feedback system.
Basically, the TrueForce feedback system takes haptic vibration feedback to the next level with racing sims. With it, the Logitech G923 vibrates in accordance to the in-game situation. For example, when playing Gran Turismo Sport, for instance, the wheel will vibrate in accordance with your car’s engine purring. Step on the accelerator, or drive over a rough patch of road, and the vibrations on the steering wheel will get more intense to reflect them.
Of course, the games you play will have to support them to begin with. In addition to Gran Turismo Sport, other games that will support the feature include GRID and Assetto Corsa Competizione. As long as the game supports the feature, you can get the feature to work on PC, PS4 and Xbox One. It also comes with two different layouts representing the two consoles, both of which work with PCs.
The Logitech G923 is priced at US$399.99 (~RM1680). It’s currently still in pre-order in the US though, and there’s no word on local pricing and availability just yet.
(Source: Logitech)
