As with many PCs, the Dell XPS desktops get a refresh every once in a while. This time around, the company is giving its desktop towers not only a spec update, but a new look as well.
On the inside, the Dell XPS desktop now features Intel’s 10th generation processors. On graphics, you have a choice between up to an Nvidia GeForce RTX 2070 Super or an AMD Radeon RX 5700 XT. The desktop will also come with either a 360W or a 500W PSU depending on the graphics option you pick. It also starts with a 1TB 7200RPM HDD, but you can also choose to have an M.2 MVMe SSD instead, or even both.
On the outside, the Dell XPS desktop tower has moved array of ports to the right side, and pushed the optical disc drive upwards. The entirety of the bottom half also now looks like a massive ventilator grille. Overall, it is also smaller than its previous iteration, with a 19L compared to the previous generation’s 24L.
The price of the Dell XPS desktops start from US$649.99 (~RM2776). For now, there’s no word on its exact configuration options, their corresponding price, or availability on our shores just yet.
(Source: The Verge)
