Back in May, Logitech has unveiled a new gaming keyboard in the form of G913 TKL Wireless Gaming Keyboard. Also known as the G915 TKL in certain markets, it is now available for purchase in Malaysia.
In case you missed our previous report, the G913 TKL is essentially the compact iteration of the previously released G913 Wireless Gaming Keyboard. The TKL in its name refers to its tenkeyless nature which is the name that is generally given to full-sized keyboards that are not equipped with number pad.
The G913 TKL is equipped with Logitech’s signature LIGHTSPEED wireless tech that allows it to provide a 1ms report rate and low latency connectivity. However, the keyboard also comes with Bluetooth capability which allows it to be used in multiple devices without the need for the Lightspeed USB receiver and gamers can still utilize it as a wired keyboard during charging which takes under four hours to be completed.
You can choose to obtain the G913 TKL in three different mechanical key switches: GL Clicky, GL Tactile, and GL Linear. Our quick check showed that all three options are available through Logitech Flagship Store at Lazada and regardless of your choice, all of them have the same price tag of RM 929.
Since earlier this week, Logitech has begun taking pre-order for G913 TKL through its Lazada store and has offered the G604 LIGHTSPEED Wireless Gaming Mouse as well as a keyboard sleeve as freebies. Better hurry though, as the pre-order will end today before the keyboard is shipped to customers starting from 13 July.
