You know the name Cooler Master for its PC casings and fans, the occasional peripheral, and more recently, gaming chairs. The company has announced that it has made said chairs available in the country. And alongside the chairs, it is also bringing in what it calls a gaming mat.
The first two gaming chairs are called the Cooler Master Caliber R1 and Caliber R2. The two are actually very similar, with the later being slightly larger, and with more adjustability to its armrests. Both are made with perforated PU leather for breathability in the material.
And then there’s the Cooler Master Caliber X1. More premium than the other two, it is not only larger, but also more adjustable. The armrests can be adjusted in four dimensions as opposed to the one and two of the Calber R1 and R2, respectively. You also get seat rocking in addition to reclining, and you can set the tension to make it either more stable, or more rockable.
The fourth chair, the Cooler Master Ergo L, is more of an office chair than a gaming chair. Unlike the other chairs, the Ergo L comes with an aluminium frame, with the kind of mesh you often see on other office chairs. You also get an adjustable headrest, something not offered by the other gaming chairs.
And finally, there’e the Cooler Master FM510 gaming mat. Regardless of what its name suggests, you can think of this as a mat for your chair that’s the equivalent of a mousepad for your gaming mouse. The company says it’s even made out of the same material as its mousepads.
The Cooler Master Caliber R1 and R2 are priced at RM899 and RM999, respectively. The Caliber X1 and the Ergo L, on the other hand, come with price tags of Rm1299 and RM2299. As for the FM510 mat, this has a price of RM299. The company says all of them are now available in Malaysia, so you can get them right now if any of them sound like something you’ll pick up.
(Source: Cooler Master [1], [2], [3], [4], [5])
