HONOR has opened the floodgates on a wide range of products, which included the MagicBook Pro 2020. Another entry among them is the HONOR Pad V6 tablet.
In front, the Pad V6 comes with a 10.4-inch 2k (2000 x 1200) display. And on the inside, it comes with a Kirin 985 chipset. It also has 6GB of RAM and a choice between 64GB an 128GB of internal storage. This is expandable via microSD by 512GB.
Another thing that can be found on the inside of the HONOR Pad V6 is a 7250mAh battery. The company claims that this allows it to play up to 13 hours of 1080p videos, or help you do 10.5 hours’ worth of work. On the software side of things, it runs Magic UI 3.1. It also has support for the HONOR Magic-Pencil.
On cameras, the Pad V6 comes with a 13MP f/1.8 rear camera and an 8MP f/2.2 wide-angle front-facing camera. When held horizontally, you’ll see the camera on the top side, sitting inconspicuously in the middle.
According to its page on the Vmall official store, the price of the HONOR Pad V6 will be revealed on 13 June. As for when it goes on sale, all the company says is sometime in June, which will likely be on or after the day its price is announced.
