It’s not often that you come across gaming hardware with two brands’ names attached to them. But the HyperX x Ducky One 2 Mini is just that. As the name makes obvious, this keyboard is born of a collaboration between HyperX and Ducky, both gaming peripheral makers from Taiwan.
Some of the features of the HyperX x Ducky One 2 Mini include the former’s Red switches, which behave similarly to the Cherry MX Reds. As you’d expect from a gaming keyboard, it also features full anti-ghosting and N-key rollover. They also come with RGB backlighting.
As the Mini in the name suggests, the keyboard is small. Not only does it not have the number pad, it ditches the arrow keys and the F keys as well, to achieve the 60% form factor. It connects to your PC via a USB-C to USB-A cable, with the former being plugged into the keyboard.
According to Back2Gaming, the HyperX xDucky One 2 Mini is priced at US$109.99 (~RM476). It will be available starting 12 May 2020, but there are only 3700 of the keyboard around. If you want to get one, then you can order one from the HyperX Online Shop, linked below.
(Source: HyperX via Back2Gaming)
