Gigabyte has announced a new graphics card under its new Eagle series lineup. The card in question is called GeForce GTX 1650 D6 Eagle OC 4G.
The card’s design isn’t too far of a leap from the brand’s AORUS lineup; instead of the AORUS logo, the card’s cooler shroud has acrylic panels with the word “EAGLE” that light up in blue when you turn on the PC. Speaking of lighting, the dual-fans also show off the same blue colour lighting that is visible when in operation.
Specs-wise, the GeForce GTX 1650 D6 Eagle OC 4G comes with 4GB GDDR6 memory running at 12Gbps and a core clock of 1815MHz. It also has a memory bus of 128-bit and to run it, the card requires one 6-pin PCIe power port. Ports-wise, the card has one DisplayPort 1.4 port, one HDMI 2.0b port, and dual-link DVI-D port.
For cooling, the card uses Gigabyte’s Windforce 2X cooling system that comes with the brand’s own zero RPM technology, that in turn cools down the composite copper heat pipe that site on top of the GPU.
At the time of writing, Gigabyte did not specify local pricing or availability.
(Source: Gigabyte)
