Barely two weeks left before 2019 wraps up but that doesn’t mean there is no longer new products coming into the market. For example, Acer is prepping up to unleash a new Predator gaming monitor into Malaysia next week.
Originally revealed to the world during the next@acer event in New York earlier this year, calling the Predator CG437K P a monitor maybe a little bit too much for some folks out there. This is because the sheer size of its 43-inch VA display which also has native resolution of 4K and 120Hz refresh rate that can be boosted further to 144Hz.
In addition to being an NVIDIA G-Sync Compatible and VESA Certified DisplayHDR 1000 display, the Predator CG437K P also has a DCI-P3 colour gamut coverage of 90% and Delta E<2 rating. Not to forget, users can choose to install LED strips on the display and customized their output through the RGB Light Sense app.
As mentioned earlier, you can look forward to check out the new Predator CG437K P 4K HDR gaming monitor towards the end of this month at selected Acer dealers throughout the country. Priced at RM 4,699, you can also choose to order it directly from Acer Online Store on Lazada and Shopee.
