HMD Global revealed its first ever Nokia smart TV during a recent launch event held in Cairo, Egypt. The Nokia 55-Inch Ultra HD Android TV is a Flipkart exclusively and will be available in India on 10 December 2019.
The Nokia smart TV, also known by its designation “55CAUHDN”, has a 55-inch display with 4K UHD resolution via an ADS panel, which is a variant of the IPS technology. It provides a 60Hz refresh rate, 400 nits peak brightness, a contrast ratio of 1200:1, and 178-degree viewing angles. Other than that, the display also supports HDR and Dolby Vision. From a design standpoint, the TV sports a clean minimalist look with thin bezels around its display.
Under the hood, the Nokia TV is equipped with a quad-core Cortex-A53 CPU paired with a Mali-450 GPU, 2.25GB RAM, 16GB storage, and also Bluetooth 5.0 and Wi-Fi support. Audio-wise, the TV is equipped with an integrated soundbar system by JBL at the bottom of its display, which supports Dolby Audio and DTS Tru Surround. For wired connectivity, it is equipped with 3 HDMI ports, as well as 2 USB ports.
In terms of software, the 55-inch Nokia TV runs on Android TV 9.0 with Chromecast support. Other pre-installed applications include Netflix, YouTube, and many others.
The Nokia 55CAUHDN TV is priced at INR41999 (~RM2448), and is exclusive to Flipkart and the Indian market for now. Nokia has not disclosed any plans for a global launch at this time.
[ Source: Flipkart via Nokia (Facebook). ]
