HP Malaysia has just announced two laptops for the local laptop market. They are the Elite Dragonfly and the Spectre x360 13. Both are lightweight convertibles which the company says are designed with productivity in mind.
The HP Elite Dragonfly is a new entry into the company’s lineup of productivity convertibles. Its starting weight is rated below 1kg, making it extremely light. It also comes with an 86% screen-to-body ratio, taking up as little space as possible beyond its 13.3-inch display. You can also have a choice between Full HD and 4K for resolution. Other items in its spec sheet include an 8th generation Intel Core processor, 16GB of LPDDR3 SDRAM, up to 2TB of PCIe SSD, and up to a four-cell 56.2Wh battery which boasts up t 24.5 hours of battery life.
The HP Spectre x360 13, on the other hand, comes with a refreshed spec sheet over its previous iteration. It’s even smaller than before now, being 13% smaller than the previous generation. It also boasts a 90% screen-to-body ratio. The 13.3-inch display comes with either Full HD or 4K resolutions. Beyond that, it comes with a 10th generation Intel Core processor, 16GB of LPDDR4 SDRAM, up to 2TB of PCIe NVMe M.2 SSD and a four-cell 60Wh battery, which can give you up to 22 hours of battery life.
HP Malaysia says that both the Elite Dragonfly and the Spectre x360 13 are already available. Their prices start from RM6500 and RM5499, respectively, at their base configurations.
