Pokemon Sword And Shield May Corrupt microSD Cards
Pokemon Sword and Shield
Pokemon Sword and Shield was released just last Friday, and it’s already causing a stir beyond it’s lack of a National Pokedex. A number of players have voiced out on Twitter and Reddit that their copies of the game were wiping all the Nintendo Switch data on their microSD cards. That was not actually the case, but instead the SD cards were corrupted, which may amount to the same thing.
Dataminer and Switch hacker SciresM took a look into the issue, and identified the Switch’s exFAT driver as the culprit. It reportedly has a tendency to get corrupted by Sword and Shield crashing. Though as of now, what exactly causes it is still unclear.
Capture
As a result of microSD card corruption, everything saved on it will be gone,. This ranges from downloaded games to screenshots. It’s unfortunate, since the former will have to be redownloaded, while the latter are lost forever unless you’ve made backups. Save files should be unaffected,  since they’re saved in the Switch’s system storage. It’s also important to note that these seem to be only affecting eShop versions of Pokemon Sword and Shield.
At any rate, the solution to this would be to use a microSD card that are formatted to FAT32 instead. Owning a physical copy may help as well, since the corruption issue seems to be limited to the downloaded versions. Speaking of which, if you’re looking to get a physical copy of Pokemon Sword and Shield, you should probably take advantage of Gamers Hideout’s trade-in deal while it’s still available.
(Source: Twitter [1], [2], Reddit via GamesRadar+)
Updated 12:38 pm, Mon, 18 November 19
