Illegear announced a refresh for their LAGUNA series gaming laptop called the LAGUNA SE. The line up is bound for a refresh as the first LAGUNA series was launched back in 2017.
To start off, the LAGUNA SE sports an Intel Core i7-9750H. You will be able to choose from three different GPU options – the NVIDIA GeForce GTX 1660Ti, the RTX 2060 or the RTX 2070.
The laptop is fitted with a 15.6-inch Full HD 144Hz bezel-less IPS display with sRGB 100% colour reproduction and 5ms response time. Weighing at 1.9kg, the laptop also has a quad-heat pipe set up with the dual cooling fan underneath the chassis. The LAGUNA SE also comes with a membrane programmable RGB keyboard.
Moving on to the memory, there will be two slots available to support up to 32GB of DDR4 RAM. As for storage, the laptop has two M.2 PCIe SSD slots and one 2.5″ SATA slot. Each slot can accommodate up to 2TB of storage, pushing the maximum possible internal storage up to 6TB of storage.
In terms of pricing, the NVIDIA GeForce RTX2070 variant starts from RM7098, while the RTX2060 configuration starts from RM5,998. On the other hand, the GTX 1660Ti variant’s price starts from RM5,299. It is important to note that prices may vary based on the actual configuration.
