The microphone isn’t something that streamers would necessarily want to have on-stream. That said, Razer has made one with the sole purpose of being prominently displayed. It’s called the Razer Seiren Emote, which comes with an 8×8 LED display.
As you might have guessed from the name, the Seiren Emote can display emotes in sync with on-stream events. Streamers can have it display emotes when someone subscribes, donates, thanks them, or basically any other on-stream event.
At launch, the Seiren Emote has over 100 preset emotes, including both static and animated ones. Streamers can use the Razer Streamer Companion App to customise emotes that pop up based on events that occur, as well as upload their own static or animated emote.
Beyond it’s main feature, the Razer Serien Emote comes with slight improvements over the Seiren X. It’s also already available on the Razer Online Store for RM715.
