As promised, OnePlus has officially taken the drape off its new flagship phone, the OnePlus 7T. Prior to today’s launch event, we’ve already been treated to its physical design and at the same time, the company has also confirmed that the phone comes with 90Hz display. Now, it is time to go through other elements within the new phone.
For starters, the OnePlus 7T 90Hz Fluid Display (as the company calls it) consisted of a 6.55-inch Full HD+ AMOLED panel with a pixel density of 402 ppi. Also featured an in-display fingerprint scanner, the 20:9 display also supports HDR10+ and has a maximum brightness level of 1,000 nits.
At the same time, the display also housed a selfie camera with a 16MP Sony IMX471 sensor and f/2.0 lens within its teardrop-shaped notch. As for the phone’s rear camera setup, the OnePlus 7T’ main camera relies on a 48MP Sony IMX586 sensor and f/1.6 7-elements lens with both optical as well as electronic image stabilization system.
OnePlus 7T’s rear camera module also includes a 12MP f/2.2 telephoto camera with 2x optical zoom, as well as a 16MP f/2.2 ultra-wide camera. For those wondering whether the phone has a low-light mode, the answer is yes, in the form of Nightscape mode which is available for OnePlus 7T’s main and ultra-wide cameras.
In terms of firepower, the OnePlus 7T carries a Qualcomm Snapdragon 855 Plus with 8GB LPDDR4X RAM as standard. The phone also can be obtained with two UFS 3.0-based storage options: 128GB and 256GB. The phone also comes standard with a 3800mAh battery that supports OnePlus’ own Warp Charge 30T fast charging tech. Through this feature, OnePlus 7T’s battery can regain its capacity from 0% to 70% in just 30 minutes.
To be available in India later this month, the OnePlus 7T 128GB will be going for INR 37,999 (~RM 2,240) while the 256GB model is listed at INR 39,999 (~RM 2,358). However, the phone’s availability in Malaysia is not yet known at the moment.
(Source: OnePlus India.)
