Looks like making smart TVs is the latest trend among smartphone makers these days. OnePlus is said to be launching its own set of Android TVs. Lenovo subsidiary Motorola looks to have beaten it to the punch, launching its own set in India.
The Motorola TV comes in a size range between 32 and 65 inches. The 32-inch model comes with Full HD resolution, while the 43-inch model has a choice between Full HD and 4K. As for the larger models, they are only available in 4K. Across the range though, you’ll get a viewing angle of 178 degrees, Dolby Vision and HDR 10.
The TVs also come with a built-in 30W soundbar, with DTS Tru Sound and Dolby Audio. On the inside, there’s a Mali 450 GPU, 2.25GB of RAM and 16GB of internal storage. Being an Android TV, it runs Android 9.0.
The Motorola TV comes with a total of six different models, based on the sizes aand resolution mentioned earlier. Their prices ranges from INR13999 (~RM817) to INR64999 (~RM3794). They will be made available in India on 29 September, but there’s no word on their availability outside on India as of now.
(Source: Motorola / YouTube via Engadget)
