Back in April, Digi has begun to offer its Home Fibre service in selected areas within Klang Valley. This came not long after the telco rolled out the service at NFCP pilot areas in Jasin, Melaka and the company has then announced the availability of the service in Sabah earlier this month.
As you might know, Digi Home Fibre is available in four different speed:
Digi Home Fibre 50Mbps: RM 99 per month
Digi Home Fibre 100Mbps: RM 129 per month
Digi Home Fibre 500Mbps: RM 159 per month
Digi Home Fibre 1Gbps: RM 199 per month
In conjunction with the launch though, customers in Sabah will be able to obtain Digi Home Fibre services with a lifetime rebate of RM 10 per month for the 50Mbps plan and RM 20 per month of the higher speed plans. However, this rebate is only applicable if they obtain the service with at least Digi Postpaid 80 plan.
Meanwhile, Digi didn’t exactly specify which areas in Sabah is already covered by the service. Hence, you might want to check out Digi’s official website to see if your home is within the coverage area of Digi Home Fibre service.
