Brian Shen, Vice President for OPPO, recently teased an upgrade for the brand’s quick-charging technology, VOOC. The teaser, made via Shen’s official Weibo account, indicates that the new SuperVOOC charger, even hints at its capability of fully charging a 4000mAh battery in mere minutes.
Of course, eagle-eyed viewers can see that the post is rather vague with some points. Specifically, the actual wattage used with the new SuperVOOC charger, as well as the exact number of minutes the charging process actually takes. On that note, online speculation suggests that the upgraded charger could be rated at 80W, which clearly higher than the VOOC charger bundled with the Find X Lamborghini Edition.
For context, OPPO’s Find X Lamborghini Edition that first launched in 2018 ships out with a 50W SuperVOOC charger. Making it one of OPPO’s most powerful chargers. In practice, the charger is capable of charging the 3400mAh battery of the Find X Lamborghini Edition from 0% to 100% in just 35 minutes.
Beyond the post, there isn’t a whole lot of information about the revamped SuperVOOC charger. That said, it is highly possible that it will make an appearance alongside OPPO’s supposedly new Reno flagship device.
