You might be wondering whether the Samsung Space Monitor series is as unique as its own name. To us, the answer is definitely yes due to its rather unconventional clamp-based movable arm that is designed to provide maximum desk space for users.
Originally priced at RM 2199, the 32-inch variant of Space Monitor SR750 can now be obtained at RM 1,649 instead, thanks to the on-going Samsung Gemilang Celebration promotion. Equipped with a 60Hz VA panel, it has native 4K resolution.
https://www.youtube.com/watch?v=KxU12mpLWcY
On another hand, the monitor is also available as a 27-inch WQHD model. Usually priced at RM 1799, the monitor is now going for RM 1349 which seems like a pretty good deal and for gamers out there, do note that this model also features a 144Hz panel.
Aside from these two, here are other monitors that are part of the Samsung Gemilang Celebration promotion:
Do note that this promotion is being offered directly at Samsung Malaysia’s official website and will end on 6 September 2019. So, better don’t sleep on it, if you like what you are seeing above.
(Source: Samsung Malaysia – 1, 2, 3)
