Most gamers might know this particular brand for their gaming peripherals and headsets but Armaggeddon does have plenty of other gaming-related products under its wing. That includes gaming monitors such as the Pixxel+ EFX 27UHD Switx which is one of the most affordable 4K monitors that we’ve ever seen in the market.
This particular model features a 27-inch IPS display that has a native 3840 x 2160 resolution and 99% RGB coverage. Together with 5ms response time, the Pixxel+ EFX 27UHD Switx refresh rate can go up to 144Hz although this can only be achieved at 2560 x 1440 resolution while it is still limited to 60Hz when it is set to 4K resolution.
With the ability to support AMD FreeSync tech, Armaggeddon also claimed that Pixxel+ EFX 27UHD Switx can also be used with NVIDIA G-Sync although it is not officially listed inside NVIDIA G-Sync Compatible database. The EFX 27UHD Switx also comes with two HDMI 1.4 ports and one HDMI 2.0 port as well as one DisplayPort input.
If you are in the market for a highly affordable 4K monitor, the Pixxel+ EFX 27UHD Switx is now being offered at RM 1,199 instead of its usual price of RM 1,499. To get your hands on the monitor, just head on to the brand’s official Lazada and Shopee store.
