With less than a month to go before Samsung Galaxy Note 10 to be officially unveiled to the world, it is natural to expect some leaks making its way out into the world. True enough, one major set of images came into the light which provides a good look at the general design of the upcoming phone.
Based on these photos, there are certainly plenty of elements within the upcoming Galaxy Note 9 that will set it apart from its predecessors. For example, its display bezel is much thinner than before which made possible by the implementation of the Infinity-O display into the phone that also features a hole-punch selfie camera right in the middle.
While the side profile of phone showed that Samsung once again has implemented the curved edge design as per Galaxy S10+, the Galaxy Note 10 will feature a different set of rear cameras in the form of a vertically arranged triple camera module.
It has also been noted (heh) that no physical fingerprint reader has appeared on any of these images. Since this particular set of leak doesn’t include pictures of the top or bottom part of the phone, we still have no idea whether Galaxy Note 10 will feature the 3.5mm audio jack or otherwise.
Given that these images were released by prominent serial leakers, Ishan Agarwal and Roland Quandt, there is certainly a seal of confidence behind them. Nevertheless, expect more to come as we get close to the next Samsung Galaxy Unpacked event on 7 August.
(Source: Ishan Agarwal with MySmartPrice // Roland Quandt with Winfuture.)
