There have been a lot of leaks regarding the upcoming Samsung Galaxy Note 10, alongside its larger variant. For the longest time, it was thought to be called the Note 10 Pro. But recent leaks suggest that it will instead be called the Note 10 Plus, in line with the naming convention of the Galaxy S series.
TechTalkTV was sent hands-on photos of what appears to be an actual Samsung Galaxy Note 10 Plus. Or so the boot screen says, at least. A number of its physical appearance matches previously leaked renders, such as the single Infinity-O front-facing camera at the centre. The same applies to the back, with the triple-camera setup being shown in a blurry shot.
The buttons and their position adds up as well. Some of the previous rumours and leaks suggest that the buttons will be back, with the power button and the volume rocker both being on the left side. From the hands-on shots, the two buttons are indeed visible on the left, albeit not very clearly.
That said, there are no shots of the phone from the top or bottom. Because of this, the survival of the 3.5mm audio jack is still in question. But with August getting ever closer, it won’t be too long before we find out for sure.
(Source: TechTalkTV via Forbes)
