We’ve seen the HP Spectre Folio late last year, and have always wondered if it will make its way to Malaysia. Turns out it will after all, as announced by HP Malaysia.
By now, it’s already a pretty familiar machine, and with a familiar spec sheet. On the outside, it comes with leather covering its inner metal frame. The 13.3-inch convertible can run in three modes – laptop, tent and tablet for a variety of use scenarios.
For its display resolution, it comes with Full HD and 4K display options as before. On the inside, you can have up to an 8th Gen Intel Core i7-8500Y processor, 16GB of DDR3 RAM, and up to a 2TB SSD for storage.
The HP Spectre Folio is priced starting from RM7999. HP Malaysia says it is already available now, but you can also pre-order it from Harvey Norman. Specifically, you can get the base model for RM300 less, or RM7699.
