Apple recently has revealed a set of updated specifications for its 13-inch and 15-inch MacBook Pro with Touch Bar. Among such update includes the 9th generation Intel Core i9 8-core processors for the 15-inch model which the company has claimed as “the fastest Mac notebook ever”.
Priced at RM 12,199, the base model comes with Intel Core i9-9880H CPU, 16GB DDR-2400 RAM, 512GB solid state drive, and AMD Radeon Pro 560X 4GB GDDR5 graphics. Of course, you can also opt for the maximum specifications which includes Intel Core i9-9980HK CPU, 32GB DDR4-2400 RAM, 4TB SSD, AMD Radeon Pro Vega 20 4GB HB2 graphics, and a RM 28,699 price tag.
Apple has also added the 9th Gen Intel Core i7-9750H option in the list which is accompanied by 16GB DDR4-2400 RAM, 256GB SSD, and AMD Radeon Pro 555X 4GB GDDR5 graphics for RM 10,499. Switch to the max specs with 32GB DDR4-2400 RAM, 4TB SSD, and AMD Radeon Pro 560X 4GB GDDR5 graphics, the price would then go to RM 25,899.
As for the 13-inch model, Apple has provided it with an 8th Gen Intel Core i5 quad-core chip which we not able to pinpoint its exact model number. That being said, the listing of Apple Store stated that the CPU has a base clock speed of 2.4GHz and Turbo Boost speed of 4.1GHz.
There is no discrete graphics for this particular model though and relies on the integrated Intel Iris Plus Graphics 655 GPU. The base model comes with 8GB LPDDR3-2133 RAM and 256GB SSD alongside a price tag of RM 7,849.
The maxed out model on another hand featured an unknown Intel Core i7 quad-core model which has base clock speed of 2.8GHz and Turbo Boost speed of 4.7GHz alongside similar Intel Iris Plus 655 integrated GPU. Priced at RM 15,149, it is also equipped with 16GB LPDDR3-2133 RAM, and 2TB SSD.
To get your hands on these MacBook Pro with freshly updated specs, just head on to Apple Malaysia’s official website.
