Maxis has announced that it’s refreshed its MaxisONE Prime plans, and it now provides unlimited data for both home and mobile lines. You’re also free to choose any MaxisONE plan and home fibre plan as part of the MaxisONE Prime combo.
When signing up for the new MaxisONE Prime plans, you’ll now have to pick your home fibre plan, followed by your mobile plan. Since Maxis is promising unlimited data for both, the home fibre plan you choose will determine the connection speed, as well as if you also get unlimited calls.
You also get to pick between MaxisONE Plan 98, 128, 158 and 188. Since they will all get unlimited data as part of the MaxisONE Prime combo, the plan you get will determine the number of Share Lines that you can add on. To illustrate, the MaxisONE Plan 98 only allows for one extra share line, while MaxisONE Plan 188 allows for up to four.
This means that you can have unlimited data for home and mobile starting RM187 a month. you can check out the web page of the refreshed MaxisONE Prime plans for more information on possible permutations.
