The new iPhones – the XS, XS Max and XR – will be making their way here next week. In light of this, telcos are also opening up their pre-orders for the new Apple smartphones. U Mobile is no different, and here’s what it’s offering.
Starting with the iPhone XS, the total that you’ll have to pay for the 64GB model will total up to RM4591. As for the 256GB model, the total comes up to RM5191, and the 512GB variant will set you back RM6091. Every option here is at least RM400 cheaper than Apple’s official prices, with increments in savings the higher the device tier you go.
On to the iPhone XS Max, we’re looking at prices of RM4991, RM5591 and RM6491 for the 64GB, 256GB and 512GB versions, respectively. In terms of savings, it’s more or less the same as the iPhone XS above – the most affordable model is about RM400 less than getting it from Apple directly.
And finally, there’s the iPhone XR. With this model, the prices total up to RM3291, RM3491 and RM3951 for the 64GB, 128GB and 256GB models, respectively. Being the most affordable of the bunch, savings also take a small dip. But you’ll still be paying RM300 less than if you get them from Apple.
Whatever your choice of device, it looks like U Mobile is only bundling them with the P99 plan. This means that you’ll get unlimited calls to all networks, unlimited high-speed data and 10 sen SMS rates to all networks.
(Source: U Mobile)
