G.SKILL officially announced its new Trident Z RGB DC DDR4 memory kits. Designed to work in tandem with select ASUS Z390 motherboards, the new memory modules is now available in 32GB x2 kits, which provides consumers a total of 64GB of DDR4 memory.
Specifically, the new memory modules will work with the ASUS ROG Z390 Maximus XI Apex, ROG Maximus XI Gene, and the ROG Strix Z390-I Gaming. Like its predecessor, the Trident Z RGB DC memory kit requires no additional power connector in order to power up the RGB. As it draws power directly from the motherboard’s DIMM slots.
Speed-wise, the Trident Z RGB DC memory modules will be available in two frequencies, 3000MHz and 3200MHz. Both variants will have a CL Timing of 14-14-14-34. But the 3200MHz variant will have an additional CL Timing option of 14-15-15-35. All variants of G.SKILL’s memory modules will require a voltage of 1.35V. They also support Intel XMP 2.0 profiles, allowing users to overclock the memory modules, should they so choose.
